Now I'm ready to add the IR sensor, which will be used for learning mode; basically reading the IR codes from an existing remote control. I'll also add a pushbutton to switch modes between learning and command and a transistor circuit for the IR LED, which will send the IR codes to the device you're controlling.
Below, I have attached Fritzing images of the breadboard and schematic.
NOTE: The Fritzing library did not include the voice recognition board, so I used a breakout board with similar connections.
