This little wiring mess is the current hardware test hardness (you can see the BlueBasic board hidden at the back there). It contains a SPI device, an I2C device, and a 1-wire device. After getting all the basic protocols working, I think I need to rework the BASIC constructs a little to make it easier to use. Should keep me amused today.
Tim Wilkinson
