I am adding something to my portfolio when building this that probably should have been added a while ago. I am building the communications schedule for the USB setup. I am using http://www.usb.org as a base site to collect some of the specifications and the checklist on prepping the USB for work.
The parts for the reflow oven are now officially on their way, and they will arrive in due time. Here are the parts that I ordered/using.
Crydom D2425 (arrived)
ATMega328
2 22pf ceramic capacitors
16MHz Crystal
Button Switch
Radio Shack Perfboard (here)
Repurposed Heatsink
14g Wire (here)
16X2 Display
I have also decided to keep a rolling playlist in the description. I will take note of updates in text, but most updates will occur in the video playlist.
Krinkleneck
