Hackaday.io Hackaday.io
Sign up Log in
VFD Shenanigans
A guy gave me this display back in college about 10 years ago.
I finally got around to it.
gabrielGabriel
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
29 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
887
0
29
8
Team (1)
  • gabrielGabriel
Join this project's team
pic vintage display VFD 16F886 FLIP Oldschool IEE
This project was created on 08/12/2014 and last updated 12 years ago.
Description
I set out to write a driver for this IEE FLIP VFD screen.
I wanted to write a parallel input driver for added vintage points but I hooked up the WR pin to the MCLR pin on my Dev. board and damaged the pin when I programmed the PIC.
After about 30 minutes of denial, I decided to continue on but writing a serial driver.
In the end it was a whole lot easier than I thought. Getting the screen to write characters with Commas and Decimal points was a bit tricky.
The screen is Alpha Numeric, it doesn't take the whole ASCII Table and uses the unused ASCII characters for other things.
For example: ASCII 0x20 with a comma is replaced by 0x80
I had to write an interpreter function to change characters to their equivalent character with comma or decimal point.
Ill post the driver once its fully tested.
Project Logs
Collapse
  • The Codes
    Gabriel • 08/19/2014 at 17:35 • 0 comments
    Code can be found here:
    CCS Compiler.
    http://www.ccsinfo.com/forum/viewtopic.php?p=189831#189831
View project log
Log In/Sign up to comment
Sign up with Github
OR
A collection of miscellaneous libraries and drivers for Micropython
Project Owner Contributor
Various Micropython Libraries and Drivers
dehipudeʃhipu
Putting Marlin 2.x on the Cricut Expression because, well, why not? Also, some reverse engineering on CRV001
Cricut Hacking
jc-nelsonJ.C. Nelson
A 160x80 color LCD display that goes on top of the Trinket
Trinket M0 TFT
dehipudeʃhipu
They just keep on coming!
PewPew OLED
dehipudeʃhipu
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "VFD Shenanigans", please tell us the reason.
Send message
Remove Member
