Hackaday.io Hackaday.io
Sign up Log in
VFD Shenanigans
A guy gave me this display back in college about 10 years ago.
I finally got around to it.
gabrielGabriel
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
29 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
913
0
29
8
Team (1)
  • gabrielGabriel
Join this project's team
pic vintage display VFD 16F886 FLIP Oldschool IEE
This project was created on 08/12/2014 and last updated 12 years ago.
Description
I set out to write a driver for this IEE FLIP VFD screen.
I wanted to write a parallel input driver for added vintage points but I hooked up the WR pin to the MCLR pin on my Dev. board and damaged the pin when I programmed the PIC.
After about 30 minutes of denial, I decided to continue on but writing a serial driver.
In the end it was a whole lot easier than I thought. Getting the screen to write characters with Commas and Decimal points was a bit tricky.
The screen is Alpha Numeric, it doesn't take the whole ASCII Table and uses the unused ASCII characters for other things.
For example: ASCII 0x20 with a comma is replaced by 0x80
I had to write an interpreter function to change characters to their equivalent character with comma or decimal point.
Ill post the driver once its fully tested.
Project Logs
Collapse
  • The Codes
    Gabriel • 08/19/2014 at 17:35 • 0 comments
    Code can be found here:
    CCS Compiler.
    http://www.ccsinfo.com/forum/viewtopic.php?p=189831#189831
View project log
Log In/Sign up to comment
Sign up with Github
OR
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "VFD Shenanigans", please tell us the reason.
Send message
Remove Member
