New Folding Algorithm - Update #1
A project log for Volumetric Circuits!
A schematic editor for "3D discrete grid-aligned circuits" and building a 1-bit ALU
anderson-antunesAnderson Antunes • 12/29/2015 at 18:10•0 Comments
It is been a while, but here it is, a quick overview on the current state of the software (watch with the annotations turn on):Hope that you guys liked :)
There are still a lot of things that still need to be integrated to the algorithm before it could be released, e.g., it does not work for graphs that have node with more than 26 connections, think about the common ground node in bigger circuits. In the following weeks I'll try to commit some changes to GitHub and release an alpha version.
