ALU designed!
A project log for Volumetric Circuits!
A schematic editor for "3D discrete grid-aligned circuits" and building a 1-bit ALU
anderson-antunesAnderson Antunes • 08/20/2014 at 02:00•0 Comments
The finished the ALU design allows it perform the following operations: AND, OR, invert B, and SUM. I tried to keep the things simple, so I put an half adder instead an full adder.
The next step is gonna be simulating the whole thing in the last version of Pyrite.
