I received PCB v0000 from SEEEDSTUDIO and components. SMA signals are reversed,, making the SMA connected antenna useless. I suggest to use a 17.3cm wire instead. This has been fixed in PCB v0001. I tested the board only with USB power, waiting for the enclosure to arrive to finish tests.
Pictures:
