Hackaday.io Hackaday.io
Sign up Log in
Analog Computer No. 1
In this project, I will use modern components to create a simple, old-fashioned, analog computer to explore the world of analog computation
vpugliese323VPugliese323
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2 comments
6 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 2
717
2
6
5
Team (1)
  • vpugliese323VPugliese323
Join this project's team
  • DARPA UPSIDE
  • WIRED Article
op amp Homebrew CPU Signals Processing Analog Computer
This project was created on 08/13/2014 and last updated 12 years ago.
Description
In our world today, a number of organizations, individuals, and institutions require computers that can perform advanced signals processing. Currently, digital computation is used in signals processing however digital computation is rigid (because of its Boolean nature and the continuous nature of signals) and consumes large amounts of power. In response to this, DARPA has created Project UPSIDE whose goal is to research probabilistic computing methods (which are inherently analog) that can perform the necessary calculations more efficiently while consuming less power. A secondary goal of the program is to design their computers so that they have self-configuring inputs. With the rise of neurogrid computing, one can see that analog computation will fit nicely alongside DARPA's model and view of the future of computing. At the end of this project I aim to have an open-sourced analog computer that can fit this need.
Project Logs
Collapse
  • NOTICE
    VPugliese323 • 08/21/2014 at 13:09 • 0 comments
    Work on this project will begin after I have finished work on my Hackaday Prize entry found here: http://hackaday.io/project/1333
View project log
Log In/Sign up to comment
Sign up with Github
OR
Bruce Land wrote 08/13/2014 at 12:34 • point
The first computer I learned to program was analog in 1964. They are hard to beat for getting a feel for differential equations. I did simulate a analog computer on FPGA, which is different, but MUCH faster. http://hackaday.io/project/259-Simulating-an-analog-computer-on-a-FPGA
VPugliese323 wrote 08/13/2014 at 15:26 • point
I like your approach. Despite the similar theme, I find it interesting how different our objectives are. You used an FPGA whereas I am using the traditional op - amps. Your's is designed to perform differential equations, whereas my goal is to make one that can perform image processing algorithms on simple bitmap images.
On a side note, I was wondering if you have any advice you could give me based on your experience with analog computation.
Hackaday Prize 2020
Solving the Caribbean Sargassum problem by preventing them from piling up and decaying.
Project Owner Contributor
Caribbean Sargassum Problem
anteneh-gashawAnteneh Gashaw
Art project around wearable radio-based instruments
Magetoceptia - Maria de' Medici & Maria Stuart
magnetoceptiaMagnetoceptia
Supplyframe DesignLab: 2022 Hackada…
Leveraging the idea of repair to craft functional imperfect sculptures using e-waste, as a response to tech-consumerism and growing e-waste.
The world we live in
debanshuDebanshu
The 2016 Hackaday Prize
The project D0VE Initiative (“D0VE” is an acronym for “Designed for Zero Vehicle Emissions”)
Designed for Zero Vehicle Emissions (DOVE Project)
cedar-centre-stem-hubCedar Centre STEM Hub
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Analog Computer No. 1", please tell us the reason.
Send message
Remove Member
