Source code, released under GPL 2
* Control for custom A5 electronic trigger
* Uses I2C to store settings and operate, with a switch as fallback
* ATTiny45
* Copyright (C) 2013 Paint Race Inc.
* Author Nathan Gray
* Released 2014-08-18
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 2 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License along
* with this program; if not, write to the Free Software Foundation, Inc.,
* 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA.
// Use i2c for commands & settings
#include <TinyWireS.h>
// For storing settings
#include <EEPROM.h>
// Default I2C Slave address
#define I2C_SLAVE_ADDR 0x26
//#define I2C_SLAVE_ADDR B0100001
// i2c commands
#define CMD_SET_ADDR 0x01
#define CMD_SET_ON_TIME 0x02
#define CMD_SET_OFF_TIME 0x03
#define CMD_SAFE_ON 0x0A
#define CMD_SAFE_OFF 0x0B
#define CMD_FIRE 0x10
// a5_a5_status
#define STATUS_SAFE 0x00
#define STATUS_FIRE 0x0F
// Pin definitions
#define FIRE_PIN 4
#define MANUAL_PIN 3
#define INT_PIN 1
// Memory locations
#define I2C_ADDR 0
#define ON_TIME_ADDR 1
#define OFF_TIME_ADDR 2
// Some safe defaults. solenoid should be good for 10%
byte i2c_slave = I2C_SLAVE_ADDR;
int on_time = 10;
int off_time = 100;
byte a5_status = STATUS_FIRE;
void setup() {
// Init pins
pinMode(MANUAL_PIN, INPUT);
digitalWrite(MANUAL_PIN, HIGH);
pinMode(FIRE_PIN, OUTPUT);
digitalWrite(FIRE_PIN, LOW);
pinMode(INT_PIN, OUTPUT);
digitalWrite(INT_PIN, HIGH);
// Load settings, if there
if(EEPROM.read(I2C_ADDR) != 0xFF) {
i2c_slave = EEPROM.read(I2C_ADDR);
on_time = EEPROM.read(ON_TIME_ADDR);
// Off time should be at least 10x on time, but that could overflow a byte
off_time = EEPROM.read(OFF_TIME_ADDR) * 10;
TinyWireS.begin(i2c_slave);
// Wait to let the big cap charge
delay(500);
void loop() {
if(digitalRead(MANUAL_PIN) == LOW) {
fire();
byte byteRcvd,i = 0;
int in = 0;
if (TinyWireS.available() > 0){ // got I2C input!
byteRcvd = TinyWireS.receive(); // get the byte from master
switch(byteRcvd) {
case CMD_SET_ADDR:
if(byteRcvd >= I2C_SLAVE_ADDR && byteRcvd <= I2C_SLAVE_ADDR + 1) {
EEPROM.write(I2C_ADDR, i2c_slave);
TinyWireS.send(i2c_slave);
// Need to reset now...
break;
case CMD_SET_ON_TIME:
on_time = TinyWireS.receive();
EEPROM.write(ON_TIME_ADDR, on_time);
TinyWireS.send(on_time);
break;
case CMD_SET_OFF_TIME:
in = TinyWireS.receive();
in |= (TinyWireS.receive() << 8);
if(in > on_time * 100) {
off_time = in;
else {
off_time = on_time * 100;
delay(50);
digitalWrite(INT_PIN, LOW);
EEPROM.write(OFF_TIME_ADDR, off_time);
TinyWireS.send(off_time);
break;
case CMD_SAFE_OFF:
//blinky(3);
break;
case CMD_SAFE_ON:
a5_status = STATUS_SAFE;
break;
case CMD_FIRE:
fire();
break;
digitalWrite(INT_PIN, a5_status == STATUS_SAFE ? HIGH : LOW);
// Debug
void blinky(int times) {
for(int i = 0; i < times * 2; i++){
digitalWrite(INT_PIN, i % 2 == 1 ? HIGH : LOW);
delay(100);
void fire() {
if(a5_status == STATUS_SAFE) return;
digitalWrite(FIRE_PIN, HIGH);
delay(on_time);
delay(off_time);
