After some research, I am changing my mind and inclined to use the 74HCT273 (*) as registers.
I need the Reset input and the 3 state output.
There will be:
- 4 chips for IR register (32 bits);
- 2 for PC (16 bits);
- 8 for general use registers (8 bits each).
So I'll need 14 of these guys., so far..
(*) Edit: It's not 74HCT273, the right IC is SN74ALS874BN, not very easy to find on stores, but will save many ICs, since it's the only with both Reset and 3-state outputs.
