74181 ALU study
A project log for JACA 1 & 2 Homebrew Computer
JACA - Just Another CPU Again Homebrew CPU, starting by a simple POC 4-bit CPU on circuit simulator soft. (done), then 8-bit (in progress)
andre-baptistaAndre Baptista 06/14/2017 at 21:290 Comments
Status: Studying the classic 74181 ALU chip.
Some useful resources I found:
Library of 74xx chips for Logisim
http://www.righto.com/2017/03/inside-vintage-74181-alu-chip-how-it.html#fn:hackers
http://apollo181.wixsite.com/apollo181/shift-right-with-74181
https://books.google.com.br/books?id=8uTNlPe-s_EC&pg=PA138&lpg=PA138&dq=74181+8+BIT&source=bl&ots=w0xXpIZ4tc&sig=8PbJivB4Ep5j5bZl4v6MH3HgXYA&hl=en&sa=X&ved=0ahUKEwjPyOaumL7UAhXMQyYKHS14CXcQ6AEIRTAH#v=twopage&q&f=true
Hope that helps someone as helped me. This ALU has odd functions, it's not easy to understand it.
I also made a test circuit to make sure two ALUs work well together (remember, 74181 is a 4 bit ALU).
All available on github.
