I connected two modules that are now converted to PBCs, the Clock and the Instruction Register. Between them is the Program Counter and Memory, still in a breadboard. This is the last module I plan to turn into PCB.
Everything worked fine, despite some stupid mistakes I made (these chips don't fry easily).
This video shows the modules working together:
Thanks for reading and see you next time.
