Using 74HCT273 for registers
A project log for JACA 1 & 2 Homebrew Computer
JACA - Just Another CPU Again Homebrew CPU, starting by a simple POC 4-bit CPU on circuit simulator soft. (done), then 8-bit (in progress)
andre-baptistaAndre Baptista 05/31/2017 at 22:480 Comments
After some research, I am changing my mind and inclined to use the 74HCT273 (*) as registers.
I need the Reset input and the 3 state output.
There will be:
So I'll need 14 of these guys., so far..
(*) Edit: It's not 74HCT273, the right IC is SN74ALS874BN, not very easy to find on stores, but will save many ICs, since it's the only with both Reset and 3-state outputs.
