Problems with 74181
A project log for JACA 1 & 2 Homebrew Computer
JACA - Just Another CPU Again Homebrew CPU, starting by a simple POC 4-bit CPU on circuit simulator soft. (done), then 8-bit (in progress)
andre-baptistaAndre Baptista 06/21/2017 at 22:330 Comments
Nothing is as easy as it seems at first glance. A simple 8 bit add is making my day worse.
Problem is explained in this electric stackexchange question I opened: https://electronics.stackexchange.com/questions/312354/74181-alu-not-working-properly-cascaded-to-add-8-bit-numbers/
As a fun note, I just discovered that the standard Windows 7 calc has a very useful programmer mode, which makes life a lot easier while I haven't finished the Assembler program.
