At this stage of the project, the Android Application development is rudimentary. Currently we have a few sketches outline the building blocks of the application itself. Because of the flexible build regarding the hardware there are many routes that this application could take. The main goal of the application is to allow the system to be expanded for any hacker by using configurable modules, of which can be activated through the settings.
The Modules planned to be included (not limited to):
Navigation using Google Map API
Information blocks:
- Speed
- Time
- Start/Stop time
- Battery Charge
- Distance Travelled
- Distance left
- Power Draw
Hardware Expansion:
- Locking the system, where the phone can act as a key. Obviously password protected.
- LED lights, frame lights, head lights, and many more.
Settings:
- Speed Limit
- Acceleration Rates
- Assisted Power
- Motor Identification
Once the base app is established, with the communication with the hardware protocols defined, this can allow the addition of addition modules for any hacker to increase the functionality of their build.
