I made these stools for an artwork about Chess called Orthogonal/Diagonal.
ChessStool.3dmChess Stool Rhino file3dm - 116.55 kB - 05/24/2017 at 21:45 |
ChessStool.AIChess Stool Illustrator filepostscript - 6.34 kB - 05/24/2017 at 21:45 |
I designed the stools in Rhino, but could have used a 2D Vector program such as Illustrator.
The design uses 3/4" (18mm) Baltic birch plywood, it's important to measure the actual thickness of your plywood and adjust the width of the joints in the files. The goal is to achieve a friction fit. This way you can always disassemble them later for easy transportation. I would recommend first cutting two test slots to see how they fit together.
I used a ShopBot and a 1/4" spiral down cut cutter and sanded the finished pieces. I selected T-Bone Fillets for the inside corners.
Use a mallet and a piece of sacrificial board to hammer together the legs, then the seat. Stain or oil as desired.
