Revision B source code is now on Github. https://github.com/Ayresindustries/EXT_IP_Tracker.git
This version allows the user to configure all of the parameters via the serial port and save them to the EEPROM.
After uploading the sketch to the Arduino, open the serial port monitor and follow the directions.
The main description has been edited to describe how obtaining and storing parameters via serial port is achieved.
