ZCD
A project log for 8ch dimmer
8 channel classic dimmer in a DIN box
crazychipCrazyChip 08/20/2014 at 12:040 Comments
The original Zero Crossing Detector developed:
https://cdn.hackaday.io/images/5109501408535937213.jpg
The resistors limit a current and the diodes limit a voltage from the bridge. RC output filter reduces the noise from mains. Both outputs from RC filters must be connected to Atmega's comparator. Such schematic uses two pins of Atmega.
Rich text editor
