Easy 3D printer enclosue
I needed a 3D printer enclosure to keep it warm so it could print ABS. Thais is the first go at it and it looks like it is working well.
Easy to customize enclosure for 3D printer to keep it warm so it will print ABS.
denys wrote 09/20/2018 at 08:16 • point
Rope and triangle bracing may help I s'pose, but the 3D printed corner parts are quite strong enough. I did print them in PolyMax and that is pretty tough.
And  making it with braces complicates it a bit. Feel free to mod it to your heart's content :)
fabian wrote 09/20/2018 at 07:50 • point
in my opinion construction need rope.
every construction is better constructed from triangle not rectangle.
meybe add a hole for rope and add diagonal of a square of thread/rope. the construction will become more rigid
