I have started working on the bootloader and testing a couple basic sketches.
A project log for USB TinyTracker
A USB-flash sized GSM/GPS tracker with a wide array of features
Be sure to check out NeoGPS: smaller, faster, more accurate and *totally* configurable to parse only the pieces you care about. The `fix` data structure is convenient for making queues and logs of the parsed GPS information. It is supported on most platforms.
