HF pinout guessing
A project log for OpenOpener
Open source (software and hardware) DC motor controller for electric gates
manuManu • 08/25/2014 at 22:45•1 Comment
I own an OXI receiver with a few remote controls. As I don't have a pinout of the receiver, I checked which of the 4 output pins react when the remote control is pushed.
I connected the 4 output of the 433MHz HF receiver to 4 digital inputs of an Arduino Duemillanove (with a piece of breadboard I already have for IR testing).
With a simple sketch, I detected an output pin toggles for about 500ms when one of the remote control's buttons is pushed. This receiver output will be connected to a digital input of my dual gate controller board.
The forth pin of the 10-pin header is toggling:
thin edge of the oxi Rx
xx
xx <- this pin is toggling
xx
xx
xx
(thick edge)
pin 1 & 2: antenna
pin 4: signal
pin 7: +5V
pin 10: GND
Jean-Claude Fourchette wrote 01/08/2024 at 10:01 • point
Very useful, thank you!
