Hackaday.io Hackaday.io
Sign up Log in
Audio FX | Effects
Analog & DSP
gintaras-valatkaGintaras Valatka
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
682 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
810
0
682
5
Team (1)
  • gintaras-valatkaGintaras Valatka
Join this project's team
hardware
ongoing project
audio FX effects analog dsp
Related lists
Audio Projects
This is a list of projects related to audio hardware.
This project was created on 06/03/2017 and last updated 2 years ago.
Description
Some random experiments, some old school
Like and subscribe https://www.youtube.com/channel/UC2YO4wXHmpn9QgrHh7-0TXA/videos
Check out my other projects https://hackaday.io/neris - Do not underestimate project Logs!
Project Logs
Collapse
  • Build Your Own Spring Reverb
    Gintaras Valatka • 06/03/2017 at 22:02 • 0 comments
    This appeared: https://www.facebook.com/groups/6110761372/permalink/10154485012031373
    Instructions: http://tapeop.com/tutorials/119/build-your-own-spring-reverb/
    And I also happen to have one, so this is what it sounds like:
    Acoustic guitar being played through a spring.. (iPhone recording, also picking up acoustic part).
    Guitar output is muted, not mixed, you are hearing pure spring effect. Guitar is amplified via soundcard left channel, and fed via headphone OUT into 3W PAM840 audio amplifier which drives the 4Ω input coil, OUTPUT coil is about 120Ω and being connected to HI-Z right channel. Enjoy
    On the second thought, maybe this is not a very good example, I should probably record a sample directly from a sound card.. for it to be pure... make it interactive?
    Freq scale at the top, might also do a sweep, the highs are not very vivid :D
View project log
Log In/Sign up to comment
Sign up with Github
OR
CD quality sound processing, integrated with Arduino sketches
Project Owner Contributor
Teensy Audio Library
paul-stoffregenPaul Stoffregen
Here is an AUX input hack for a 2004 Pontiac Vibe radio. ( DELCO 28022766 )
AUX INPUT FOR PONTIAC VIBE RADIO
beto-greenBeto Green
An audio-visual scrolling interface made with P5 and Tone.js
SCROLLHOLE
gina-collecchiaGina Collecchia
With carefully controlled DSP, the ESP32 can add subtle warmth while still keeping the effect fully adjustable and bypassable.
ESP32 Tube Sound Processor – Warm Analog Sound
mircemkmircemk
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Audio FX | Effects", please tell us the reason.
Send message
Remove Member
