tried to get the next step for receiving the time, not just the bits by using the code written by Mathias Dalheimer. UNforunatelly I wasn't able to compile it, same result by using the modified code from Frank Staude.
ONly to realized that this couldn't work, becuse I use an arduino micr which has an ATmega32u4 instead of a ATmega328, so alle the timer variables won't match, of course.
...so: to be continued
