Identifying the parts, and an Easter Egg
A project log for Hacking the LayerOne 2017 badge for audio... #fail
Successfully adding external audio to the badge "on a breadboard" but then bricking it when adding it permanently.
toddTodd 06/06/2017 at 03:210 Comments
The Connections
Not that you can't mostly figure these connections out without flipping it over ... but I've also identified the line out signal and GND.
The Easter Egg
When talking to one of the creators at LayerOne he let me know there's an unpopulated LC circuit for a low-pass filter on the board, to keep down excessive treble. I haven't seen a schematic from theme, but it seems likely it's this:
