The first prototype used the final motor and a attiny2313 with a clobbered together pcb. The base is just supporting the clock on one side giving it a sense of floating mid air.
One snag i ran into was that the base was too light and the clock would topple. So i added 75x5 mm studs in the base to give it some mass
