I am in the first stages of this project. Have made the first prototype board for the transmitter unit. Feel I have control with the solar panel and the pressostat.
On the breadboard is the test setup for the reciver.
Status at the moment is that I have trouble with the range on the RF link. Probably something I do wrong.
High priority now is to get the link to work over some distance.
And future expansion plans is:
- A simple led panel to inform about water level at the cabin.
- Connect the reciever to a Raspberry Pi with a 3G modem to upload temp, water level and webcam to my home server.
Anteneh Gashaw
José Miguel Díaz
electronicsworkshops
MechaTweak
Did you have any luck fixing the propblem you encountered with the the RF link? What RF module are you using?
Currently working on: https://hackaday.io/project/4698-clouden
