BREP testing framework and 73 unit test for BREP boolean operations
A project log for jsketcher
Parametric 2D and 3D modeler written in pure javascript
val-erastovVal Erastov • 10/12/2017 at 06:21•0 Comments
After my first implementation of BREP boolean algorithm I started running into the corner cases like coincident vertices/edges/surfaces and etc.
It was a time to create a testing framework  for BREP sub-system to track the regressions and to test the quality of the boolean algorithm on the crazy data.
Here is the view of my testing framework. I have creates 73 automated  tests for brep boolean so far:
Here are some examples of the corner case. All these objects are created by applying the boolean operations on a box.
