Some carrier waveform stability concerns but the FM modulation works well enough that I think it will be trivial to implement. Particularly if other implementations can be adapted. Switching to the SI5351 I hope will eliminate ll stability issues. I have read that some have observed instability with these AD9850 boards in the frequency ranges that we will need to be using; around 40 Mhz or so.
