* The total cost for the project is about $ 150.
- Each device has the function of a relay station. This helps the signal to travel further.
- All devices have power saving mode. Nrf24l01 will transmit very little signal, after each state change.
- "BUZZER" sound alarms are integrated in the device: Central Controller, Alarm and Fire alarm, Fire alarm, Water heater, Air-conditioner remote control.
- Alarm loudspeaker connects to Central Controller and "Alarm and Fire alarm". Alarm loudspeaker gives very strong sound.
- In the event of a fire alarm, all equipment will ring.
- There are two alarm modes when there is a burglar: + the underground alarm is just dialing two phone numbers. + Sound alarm, turn on the lights and call 2 phone numbers.
- All devices are linked together through wireless communication to form a network.
- Each device is a separate code, which depends on the central controller, so there will be no coincidence. First time use, will have to configure the device. Configuration is quite simple, users just press the button on the device about 6 seconds.
video: Introduction and instructions
video: Equipment in my house.
video: Introduce more features
video: Introduced inside the device.video: Self-protection feature of alarm device when power is off.
- Central Controller includes: Ethernet W5100, Arduino Mega 2560, Arduino pro mini, Nrf24l01, Adapter 5v 2A, BUZZER, relay3v3a, Button.
- Alarm and Fire alarm includes: mobile phone Itel IT2180, Arduino pro mini, Nrf24l01, relay 5v * 5, PIR sensor alarm, MQ2 sensor, Adapter 5v 3A, BUZZER, Button. "Alarm and Fire alarm" Work for 8 hours when power is lost
- Fire alarm includes: electricity supply 5v 1a, Arduino pro mini, Nrf24l01, MQ2 sensor, BUZZER, Button.
- Light switch (precarious) includes: electricity supply 5v 1a, Arduino pro mini, servo, Nrf24l01.
- Light switch (hit note) includes: electricity supply 5v 1a, Arduino pro mini, Nrf24l01, relay 5v10a.
- Water heater includes: electricity supply 5v 2a, Arduino pro mini, Nrf24l01, relay 5v30a*4, BUZZER.
- Air-conditioner remote control includes: CHUNGHOP.K-1028E chip , Arduino pro mini, Nrf24l01, BUZZER, Adapter 5v 2A,Button. (Controls all types of air conditioners).
https://github.com/blynkkk/blynk-library/blob/master/examples/Widgets/Terminal/Terminal.ino
https://github.com/ninjablocks/arduino/blob/master/SPI/SPI.h
https://github.com/arduino/Arduino/tree/master/libraries/Ethernet
https://github.com/kroimon/Arduino-SerialCommand/blob/master/SerialCommand.h
Tiendo
gTrigonakis
Pete Hoffswell
