Our aim here was to see if we could fit a useful CPU on a CPLD. We chose the Xilinx 9572 because we've used it before, and there's a breadboard-friendly dev board for it.
At the same time we wanted to see if we could describe a CPU in one page.
The 6502 is nice and simple but is too large for a CPLD and too complex to be described in one page, so we started with that and threw out the stack pointer, the index registers, and almost all the instructions. We're left with an accumulator machine, and we kept just two flags: the carry and the zero.
The first cut has a fixed instruction format of two bytes, which allows for two addressing modes: eight instructions in direct mode with a 12 bit operand, and sixteen instructions in implied/immediate mode with just an 8 bit operand. So we get a 12 bit address space, and a 256 byte zero page. We get LDA, ADD, SUB, and AND with two addressing modes, and STA. NOT, JP, JPC, JPZ and SEC with just one addressing mode.
With this version, not only must stack management be manual, but also subroutines have to be managed manually, perhaps by using a Wheeler Jump. Maybe self-modifying code would be essential. It's certainly a fully capable CPU though.
At this stage we also had an assembler and an emulator, both written in Python. See GitHub.
Ed S
