OPC-1 gets indirect addressing!
A project log for OPC-1 CPU for CPLD
A one-page CPU: spec, HDL, emulator and macro assembler each in one page. Fits in XC9572 CPLD.
ed-sEd S • 06/16/2017 at 18:00•0 Comments
Still fitting within the CPLD, and still keeping source, spec and emulator within 66 lines, we managed to add a feature: indirect addressing.
Having reduced the address space from 12 to 11 bits, so we could fit in the CPLD, it turns out we had spare logic capacity (but of course no spare flop capacity) and we also had one bit freed up in the instructions.
So now we have a 5 bit opcode field. We gain a load instruction - LDA - and the store instruction - STA - gains a second addressing mode. In both cases there's an extra level of indirection: the effective address is the value loaded from the address given in the instruction. Because the pointers are fetched using only an 8-bit address, this gives the machine a zero page, like the 6502.
We also gain a set carry instruction, SEC, hoping to make subtraction-by-addition a little easier, as we lack a subtract instruction. And we gained a little by squeezing the carry bit into the link register. We needed that - the design now uses 100% of the Function Blocks in the CPLD.
Here's the updated spec.
