Check out our latest update to both the firmware as well as the GUI. Major improvements are:
- ECG and Respiration signal filter performance improved
- Respiration rate algorithm gives more accurate results
- SpO2 calculation accuracy improved
As a result, you get nice looking signals, like the one in the below screen.
For more details and to get the code, read the full update on Crowd Supply.
