Bil Herd Well the Bios says it all, burned out years ago, have some scattered memories of working for Commodore in the 1980s's. I also was licenced to fix TVs , CBs and had my Master Antenna cert (all Indiana commerce requirements) at an early age. Worked at Pennsylvania Scale and learned all about heavy duty analog, FCC, ground loops, and things that proived usefull at CBM. After CBM I did vision systems and eventually owned an ISP which turned into a Software house, been an entrepeniur/self employed last 25 years
Hey all :-)
Square will cause extra heating
how much power do those 9v need?
on C104
or, maybe replace it with a modern low ESR cap
can i ask nonpuppy questions on that doc?
Just gonna get formal for a second: Welcome @Bil Herd !
Shulie: @DL101 Yes lol
@DL101 nonpuppy questions, yes please
@DL101 Ya the puppy thing is an attempt at a shiny object
So there are no stupid questions just stupid answers. >:)
how's your Herdware going? I think I saw something on Tindie from you
Puppy is eal, I have bite marks on my toes to prove it.
Slow, I don't really pursue it due to workload
Its more a way to capture people looking for custom
there are some impressive fast loaders
Also, we are releasing a new documentary at the Computer History Museum next Friday! (Sunnyvale)
Its about the story arc of Nolan Bushnell starting ATari and then finally the sale to Wrane
I keep pushing CHM to put in a Dr. Dobb's exhibit, but no traction :(
Warner. Chevck out 8bitgeneration.com for more info, we also did the last interview of Jack Tramiel in teh Commodore Wars story.
@Bil Herd Nice! Are you having a showing for the release?
8bitgeneration.com’s server DNS address could not be found.
bitbanging?
Hey I can try again to get you a shirt now that I know they close the shop early.
http://www.8bitgeneration.com/
Yup, Friday the 23rd, Next Friday.
I'd appreciate that @Bil Herd
thx @Jordan Bunker
So for some reason I am the narrator
The Commodore documentary is available on Steam and Vimeo
Shulie: We have some questions on the doc! :) @DL101 asks: Why didn't commodore keep up with the pc maket?
Ack, I had to refresh to see them.
Shulie: I'll post them here for you, Bil.
Commodore failed IMHO after Jack Tramiel left, we were rudderless without our leader. We had the exciting Amiga chip set and the PC was an overpriced IBM designed (overdesigned) behemouth. The guy that came in to run the engineering group (after I left) was the engineer on the PC JR and despised by all. He actually wropte a memo that said anyone calling one product the Amiga Jr would be fired. His first act was to cancel all ongoing projects and there were EXCITING projects involving ultr-high resolution with integral compression and multi processor, all in the late 80's mind you.
Commodore kept up with *you*....
The made Greg Berlin remove Ram and an MMU from his PC based design so next year's would sell well, end result was both years were a bust.... just as an example.
how can high resolution with compression work? if you have the wrong image data, it doesn't compress
Bil great job you have done back then. The little fatty was great machine.
Cs did well in Europe according to Chuck Peddle (6502 father)
so it was just bad management?
Okay, the question is about 6502 updating its architecture.
YES THIS WITH THE 65816
(Turns out I cant cut and paste the questions without install a Google app.... the bastards)
So the 65816 came out while I still worked at CBM .
i find the 65186 kinda weird cpu
Bill Mench, one of the "Motorola 5" had started Western Design Center with his sister. He called me and tried to sell me on that for a 16 bit processor and I informed him we were alreadey going to use the 68K motorola. He went so far as to tell me that the 816 was superior as it only had 2/3 registers to save during an interrupt and the 68K had 16 of those darn pesky registers.
the 68k was nice, clean and good orthogonal instruction set
wow...68000
My jaw literally dropped at this comment and I actually replied that we could just pretend to have 3 registers if that was a problem
I did a lot of dissection for the 68000 for Moto... if you have an actual 68000 try an ADDQ.L (Ax),2 -- about 25% of them made for a year will fail that instruction ;-)
He then told me I should adopt it because he just talked Apple into it.
i don't remember apple ever using that cpu?
https://en.wikipedia.org/wiki/Apple_IIGS
I am afraid I ran out of patience at this point and I was less polite of my peer than IO should have been.
I think ARM has shadow copies for all registers for fast interrupts
Bil Herd "You called me to tell me that I should use your product because my competitor is using it???"
Ya and there context switching in Sparcs, etc.
So the 68K worked well with the Amiga chip set as it buss shared nicely.
but the 816 is still in a 40 pin package
Fred Bowen also showed me that the 816 wasn't "really" compatible with our Kernal as the Kernal could not assume whether the processor was in "long" or "short" mode requiring a rewrite
Question is about 286/386 so here is my take on that line of processor: I called it the "shoebox" meaning you had a single box you could put a single tem in as in one accumulator. As the processor got faster it was all about prefetching and getting things into and out of the shoebox faster and faster. Meanwhile other architectures had contectual register swapping and other virtualizing stuff that could go way more parallel... but Intel won.
Question is about the backup sensors on cars.
it's like VHS and Betamax: Betamax was better, but VHS won :-)
and motorola failed too
In 1986 I went to work for Indian Valley owned by one of the former heads of the R&D lab at CBM. I was working on an alarm system for swimming pools to detech if aa child fell into the pool. Unlike ultrasonics in the open ocean the returns from a closed pool is a continuous stream of echo returns
CBM means Commodore Business Machines BTW, but we often said CBM, old habit
If only you had anticipated Apple and come out with the iCBM
That was a cool project.
what are you working on this days @Bil Herd
@Al Williams then he would have destiny shared with Kevin Mitnick
So we found a way to lives with a hundred milliseconds of return from a ping and actually used it to our advantage, I could stick my foot in the water behind a ladder in a bean shaped pool and it would go off but not be fooled by roap slapping the water or floating toys.
@lol AL
@Bil Herd Huh what could this be used for?
So I got tired of getting wet so I made a model of a dry swimming pool with air ultrasonic sensors, and it was really an easy thing using a sensor set used by Poloroid. One day I mounted it to the back of the company car, a black station wagon and went for a ride. I was using it to determine distance to the cars behind me, which strangely enough started slowing down when I slowed down being a government looking car with electronics hanging off the back.
hahaha
lol
We pitched he idea to an inssurance company for semitrailers, I built some into the running lights and it was a blind spot detector, even powered up from the turn signal turning on.
Last I heard, my boss Ziembicki was in a 30 year fight with ford over the patent.
The worst part is when I went to buy my SUV I had to listen to the sales guys tell me all about how he thought it worked.
lol
Anyone could have designed it, its just it was 1986 and hadn't been done yet
Wow, I got more than I bargained for with the sensors question... Fantastic story, thanks!
I have no short stories
Yeap the patents big companies and lawyers that is no fun to fight. We all will be better if patents are in public domain.
:) we know
To answer the question what I am doing these days, I have a consulting business for network and security architecture and of course a gig with Hackaday doing videos.
Also narrated a couple of documentaries that we mentioned earlier.
Is your network and security work hardware or software related?
Cisco type design.
MPLS
So the QA manager at Commodore came in to report the sad news...
The newest printer had failed the drop test badely, these units were $30K each mind you
At one point he mentioned the parts flying across the room (I examined it sliding under the door and into the hallway)
I was like "wow. It dislodged from the packaging???" His response, and I shit you not, was "packaging?" They not only were dropping printers with no box from "loading dock height", when the first one shattered they went ahead and dropped the other 2
ensuring we would have no prototype printers for another 5 weeks.
lol
Okay who here hates commodore or love Apple, go ahead, speak up
too young to have an opinion on this
Lol... guess i asked for that
not me lol, i don't have anything apple
I have still a (working) MPS-801 in my cellar
So I am reminded of the whole in the wall story....
I'm reverse I hate apple and love commodore amiga and risc based machines :)
Many of the printers I had over the years deserved serious drop tests
hole in the wall
Booo Hisss! CBM PET taught me to program :-)
My favorite was MIPS architecture.
For good or for bar I only had access to Apple ][ clones in Bulgaria
After our move to West Chester we had a new lab and I was given my own room for teh C128 emulator since it was pretty big . On the weekend the AC would be turned off and I would spray the board every 30 minutes as it would stop working from my sweat dripping on it
For whatever reason that was the design they were able to steal at the time :-D
Then one day the guards, bless their hearts, started locking my door.
Problem was the contractors had never given us the keys. I crawled over the top and got scraped and that white crap all over me in teh process.
Multi Path Level Switching (MPLS) and DWDM. Working with a couple of years ago... :-)
I wrote them a nice note explaining that there were no keys and to kindly refrain from locking it.The next day it was locked again.I wrote another note only more terse. The story about what happened next was that I punched through both walls (exterior and internal) in one punch. It actually took me two. Mind you I looked like below at the time:
The next day the door was locked again. The note this time said "Look Assholes, there is a hole next to the door so stop fucking locking it". I finally had to take the knob off the door.We put the QA manager that destroyed the printers in charge of fixing the holes... we would get weekly reports.
So anyone have names for teh puppy?
Tuft!
mopo
Cutest one I heard was Nibble, but he will grow up to be big.
that white patch is totes adorbs
He does have a tuft on his head.
Ion because he's positively charged
Ya, I picked him for that, has a white spot on his chin and way more intelligent than QA managers.
Shulie: Nibbler
Okay an Al inspired question: What flow faster, electrons or holes?
To compute the answer you need to know the speed of dark
Can I tell a Trauma Center story?
plz?
Inspired by Shulie's suggested name.
This is an easy answer... the dark is faster... whenever the light arrives, the darkness already has been there ;-)
Shulie: haha yes, please tell ussss
Holes are faster :-) Because in recombinatio you have more holes at orbital positions. :-)
We had a young lady come in that had been riding a bike and thrown into the windshield of teh car that hit her. We had to give her dozans of stiches all over her back but the worst was each injection of Lidocain caused her to scream, it was hard on everyone. At the end we gave her a little stuffed puppy for her bravery (kids are way braver than adults) and someone asked what she was naming it.
Her reply was "Stitches!"
Energy of the empty space or expanding universe yeap it travel expand faster the light :)
Holes are faster, its a hole as soon as the electron leaves it but not filled until one does... Propagation ;-)
I would say electrons, but I'm not positive.
Hole mobility is typically 2/3rd of electron mobility, I think its why NPN transistors tend to be faster than PNPs.
electron are negative haha
Holes don't make as straight of path from what I understand.
thats also why PMOS is slow right?
Ya, check out my CMOS posts, I try and hit some of the low level stuff that I learned from working in a room of chip designers.
Anyone playing with the $3,000-$5,000USD pick and place machines?
i which i had, soon ill have to mane a entire bunch of smd pcb-s with a colleague for work :/
whish*
@Shulie Tornel I see colored boxes on the sheet but nothing in the lines after the sensor
I played with Liteplacer recently, but we had an old version. Long story short, I couldn't get the precision up to snuff and gave up.
Interesting. Doesnt that depend on the material density then?
I'd love to. Got a project with about 200 of 0603 passives
mine are 0402, gotta do 20 boards
@Bil Herd Looks like that's all the questions we have
@Morning.Star lots of variable not least being doping
Shulie: Last call for questions??
I got one... @Bil Herd When are you going to be able to afford another L?
There is a story behind that. >:)
I can't say I'm surprised. Let's hear it
yes
On a friday afternoon.... we are all on for good stories... ;-)
yeap
Please Bill. :-)
My report cards started having William with one "L". I raised my hand being an inquisitive youth and asked why for my name was spelled in such a unique fashion.
The teacher replied that it was "easier for the computer"
one byte less lol
That was BS of course as it was easier for the person typing it in, the computer didn't care . I responded that one "L" was easier for me too and strated spelling it that way.
% months later I got marked off 10 points on a Math semifinal test for mispelling my name
To a now rebellious youth that cemented the deal.
Lol. I remember a PET program at school for keeping student record. To save bytes it too the first letter and the end of a name. Poor Patrick XD
xD
Turns out I invintyed a unique handle way back when, google "Bill Herd" and you get a bunch of people, google "Bil Herd" and its only me.
the only one BIl herd
Al WilliamsA bunch of people? Or a herd?
Its bin herd
I saw an old typewriter once, where in order to save space they used the same key for "1" and lowercase "l"...
All the old typewriters did that... o for 0, 1 for L....
BTW if anyone ever heard of HErdware here is the origin:
Its the Easter egg in the C128
@Al Williams Oh, then I was born into the age of the advanced typewriters :-)
I think nearly all manuals were like that... I learned on an Underwood from the 1910's--not that I am that old. I'm old but not that old.
whats the command for that?
When the programmer did this (they didnt tell me cause they knew they would never be able to bitch about not enough ROM) they found that they had to redo teh capital V in Von's name in the font ROM. The QA manager had not directed his people to press every key on the keyboard and check the results.
sys32800,123,45,6
hahaha
Also the shift Q didn't work, the user groups found it the first day of sales.
They found the easter egg by the third day by disassembling the instructions even though it had been Exclusive Or'ed with AA
or was it 55
lol
Anyone other questions?
We're done on the sheet Please come back again Bil!
that was awweosme
Thank you for speaking, Bil. I enjoyed the stories.
indeed it was
Seriously! love hearing the stories!
Kind regards Bill Best stores ever.
Thank you bil
puppy name?
Just one word of advice for everyone, don't throw silicoln wafers like frisbees, they shatter like glass and get all in your hair
Thank you @Bil Herd ! :-) Most fascinating stories... :-)
Puppies name will continue to be a place holding variable.
You didn't like Ion?
foo?
Bil Herd lonnie
Shulie: Keep adding puppy names to the hack chat page: https://hackaday.io/event/25382-electronics-design-hack-chat-with-bil-herd
Last newfys names ended in "y" sound.
whatabout some name from kerbal?
Thanks everyone, y'all were most gracious!!!
SID, VIC, PET :-)
ty!
TED, TEDDY
CMOS
thanks for coming!
LOL, Limor already has MOSFET
DIP ?
Dippy
awww Dippy
Billy
Dipshit is too common
needs more legs for this thou ;-) 4 legs DIP :-D
Drippy... cause I gotta tell you he produces lots of drippy byproducts
ew
SOT223
DL101 SC-70
Hes a DO41 if ever I saw one. I smile every time I see that picture. I curse every time he bites my toes.
Shulie Tornel
