Why did you make it?
We wanted something simple that can do the job without any special wiring or trouble. We built it to be small, reliable, and with lot of power potential. You can chose how you will connect your load (soldering directly, soldering pinhead or screw terminal).
What makes it special?
This board is small, compact, easy to assemble and use. It differs from others because small size and huge power potential. Also you can use couple of these Driver Boards to make very complicated projects of your home led lightning system, or maybe automobile uses. Possibilities are endless.
Owl Labs
Ben Lim
Jon McPhalen
bobricius
