Finalizing Circuit
A project log for Pi Purza - an IO board for Pi
got tired of connecting sensors, LCD, RTC, LEDs and buttons to a Pi, so here is a small PCB for it.
zaidpirwaniZaidPirwani 06/11/2017 at 08:120 Comments
As I started listing things down to connect with my Pi, I also realized I sometimes needed IR Sensor, sometimes a Buzzer and sometimes even a simple USART or SPI header was needed.
So, ended up with this list in the end:
Hardware (mentioned pins are BCM Pins)
OUTPUTS
INPUTS
Libraries/Software Tools (used/planned to be used)
Device Tree (/boot/config.txt)
