This is the part, where I end up writing, copying, hacking code to get things to work.
My usual route in a project like this with many different components is to first try each and every thing separately with separate code, libraries and such - as usually there are examples available online for almost everything these days - especially many many THANKS to Adafruit.
So, I made a GitHub repo to record my work for the code part - this was being done on the VeroBoard prototype while the PCBs were on their way - these LOGS are not in order - https://github.com/zaidpirwani/PiMon
The prototype setup is shown
I also had the LED blink once every second to show that the system was indeed working.
Still to do is the IR Sensor.
