The actual configurations use an electronic component to convert the volts of the batery to 3.3V to power the electronics. The next design of Emme dont need this component because with a new custom pcb the electronics can take the power directlly to only one cell of the batteries, but for now is neccesary a new cover to evacuate the hot temperature from the 3.3 volt converter,
The stl of the new cover is ready to download at the files section.
