i have been experimenting with arduino timing contol, but opted for a ready made megajolt solution for this project. it can be controlled using "mechanical advance" algorithms based on rpm, manifold vacuum, or throttle position. I am currently using rpm based advance, but believe tps advance will be the better overall solution to cure hard starting where there is not enough advance.
Duane Grzyb
