I Can Has Boards?
A project log for Home Automation System (to rule them all!)
Open automation system, starting with lights and occupancy sensing and expanding to encompass anything that has wires or electrical contacts
the-hatThe Hat 08/21/2014 at 04:380 Comments
Lots of circuit boards form OSHPark, read to be soldered into awesome.
This proof of concept transceiver will be modularly constructed, with a backplane (pictured at lower right), and a plethora of modules (pictured at left) that will be inserted into edge connectors on the backplane. Once I have decided on a transceiver design, I will make a compact and inexpensive module that can be used with an Arduino, AVR, PIC, ARM, or most other embedded microcontrollers. Pictured at top right is a simple junction box that will be used to connect multiple devices together.
Rich text editor
