I'm using the MCP73812 for battery charging.
I've decided to keep the battery charging on the blimp's gondola itself rather than dealing with pulling the battery on and off each time. I dislikeJST-style battery connectors.
After leaving the battery on charge to test the circuit overnight, I discovered that this morning, the 1-cell 3.7V Li-ion battery was at 2.8V. !!!!!!
Update: while charging, the rest of the circuit was on, so the motor was on all night. In the next rev, I've fixed that.
This is the circuit (*.sch in docs) I'm using.
