The initial design for the pcb is finished, and will be sent off to fabrication once I have more designs to panelize the design with.
As far as I know the design is complete, so anyone should be able to order one and test it out if you're really eager :)
Ben Brown
Indeed, that was my main motivation. This probably wont be an amzingly cheap item, but hopefully will work really well for a reasonable cost :)
I'm very interested in seeing how this project turns out! Electronics for solar power are so expensive. :(
