The camera test harness is built - just need to attach the camera to the base unit, adjust to centre it and then I should be in shape to start acquiring images. This project has highlighted a need for a drill press, table saw, and a t-square. Oh, I drilled the mirror-mast hole with multiple drill holes and then a nearly-fire-starting with a dremel tool. Hehehehehehehehe....
Yes the little Lego guy can see everything now. And it's awesome!
