I have a small power regulator board I put together that will be able to supply 5V to the components and Arduino but I will need a 3.3V regulator for the RasPi. There would be a barrel jack connector on the board that would power the regulators. If I have the time and money I might add a battery in the enclosure that would last a few hours and then require plugging in to charge.
Lukas Vozenilek
