2016, november: firmware
A project log for A modular sequencer for electronic music
A sequencer that offers the possibility to be connected modularly and musical operators to build up more complex live electronic music.
joaquinaldunatejoaquin.aldunate 09/10/2017 at 18:072 Comments
I couldn't go deep into the design of the firmware until I had the manufactured PCB version of the prototype, because the contacts weren't reliable, and it was hard to debug wether something was not working because of a broken connection, or because a software problem.
My plan was to take the programmed prototype to different music nerds, and allow them to build their own sequencer and make their own transgressions to it. Specially because at that time I would be a week in new york, and then in Mexico, and after that in Chile. As from from Finland it takes about a month and a lot of money to get a shipment from U.S. suppliers (for the RGB led's and the so) I bought enough materials to make other nine of these modules while I still didn't have the firmware finished, and I would receive them in New York. In this way, I could make a workshop and receive influence from other makers in many parts of the world.
Once I started developing the arduino hardware, it was easy to get the hardware to work right. I could also do some simple user interfaces such as a midi drumkit (like the korg padKontrol) or a simple 16-step sequencer.
The led's are turned on one by one by the microcontroller. Each led leg is connected to one multiplexor output, and each button aswell. The firmware is constantly scanning the two multiplexor addresses and giving a voltage or not, according to wether each led must be on or not.
//update one pixel on one of the color channels behind the mux. Be aware that redPixel function exists
void updatePixel(byte currentPixel) {
  currentPixel += 0xf;
  //nibble A is connected to the mux address for the anodes / btn inputs
  byte nibbleA = 0xF;
  //nibble B is connected to the mux for the cathodes / btn outputs
  byte nibbleB = 0xF;
  byte currentLayer = currentPixel / 16;
  if ((layers[currentLayer-1] >> (currentPixel % 16)) & 0x1) {
    //(currentPixel>>2)&12 is the same than doing floor(currentPixel/16)*4. try it  in codechef
    nibbleA &= (currentPixel % 4) + (currentPixel >> 2 & 12); //[0-15]=0,[16-31]=4,[32-47]=8,[48-63]=12
    nibbleB &= (currentPixel / 4) % 4; //~0x10 << ((currentPixel / 4) % 4); //0,0,0,0,1,1,1,1,2,2,2,2,3,3,3,3, will happen 4 times within 64 loop
    nibbleB += 8;
    //ground & power the led. strangely still works without these lines
    digitalWrite(analogA, HIGH);
    digitalWrite(analogB, LOW);
    PORTD = (nibbleB << 4) | (nibbleA);
    switch (currentLayer) {
#if COMPENSATE_R > 0
      case 3:
        delayMicroseconds( COMPENSATE_R);
        break;
#endif
#if COMPENSATE_G > 0
      case 1:
        delayMicroseconds( COMPENSATE_G);
        break;
#endif
#if COMPENSATE_B > 0
      case 2:
        delayMicroseconds( COMPENSATE_B);
        break;
#endif
//just draw a pixel disregarding the layer information
void turnPixelOn(byte currentPixel) {
  byte nibbleA = 0xF;
  byte nibbleB = 0xF;
  byte currentLayer = currentPixel >> 4;
  nibbleB += 8;
  /*PORTC |= 0b1;
    PORTC &= ~0b10;*/
https://github.com/autotel/thesis-prototype-zero/blob/1f0f84d950a1703086b56ecbf58f549703d09475/firmware_displayer/ledScreenDriver.ino
 This worked nice, but led to the problem that, the more the microcontroller was doing, the lower that the led's refresh rate would be.
I started experimenting a bit more with the interactions, to make more interesting transgressions to my initial 16 step sequencer; but I couldn't make any longer sequences. These were my mistakes:
My sequencer transgression workshop would have to wait a bit more.
Rich text editor
benmartin2227 wrote 11/26/2024 at 04:17 point
Thanks for sharing. I'm super excited to know about this casino games. Have a very good day!
clyd6868 wrote 06/19/2021 at 05:51 point
I always want to know about modular sequencers for electronic music, and I am glad I found so much information about them. By the way, earning money becomes very tough now a day,  that's why I choose an online casino where I can earn money while sitting at the home, I was reading about casinos not on gamstop and while reading about it, I am glad that I found your post in which you shared everything about electronic music.
