https://github.com/soholt/Tango [unreleased]
- Buit on Kohana, then -> Zend Framework 1 -> Zend Framework 2
- No need to install on remote servers, everything is done via ssh
- Reads ~/.ssh/config to populate a drop down box, can read hosts from db
- It is only started when nedded, php -S 127.0.0.1, shut down after use
- It is as secure as you workstation
- Building zfsonlinux.org ZFS SPL kernel modules from a web browser using checkinstall and watching the output scroll
- Tons of more goodies
