I did some project restructuring, to include:
- Directory structure: moved src/ files to rtl/ and sim/
- Created ntsc_test and restructured mojo_top to reflect it
- Updated comments in several files
- Deleted no-serial branch and replaced with video-only branch
The biggest change is the addition of BMP file output to the following test benches:
- ntsc_test_tb
- rgb_332_palette_tb
- color_bars_tb
Below is what you should see for the ntsc_test_tb output, which matches what you'd see on the television:
