Blinken Buttons
A project log for SMidi - Soft MIDI Pedals
Full function, class compliant MIDI pedals you can roll up.
masterofnullMasterOfNull 06/24/2017 at 19:380 Comments
Experimented with making 3D printable buttons.
Tried making a planer design where it could be printed flat, then the buttons popped through to become raised. Might have worked, but then it got a bit more complicated when I decided I wanted some blinken-lights.
I've settled on a layered approach so everything can be printed in the best material for the job, and without overhangs/supports.
TPU cover, clear PLA light pipe, TPU contact pad, and ABS retainer ring.
