Split Axle Installed
A project log for Water Bot
Robot Sprinkler
mary-parkerMary Parker 01/09/2018 at 21:020 Comments
Tonight I mounted a split axle onto the base of the bot for easy maneuvering. The wheels are slightly bigger than the front wheels, thanks to the suggestion given by [dohabandit] in the comments. The gears for turning the wheels are also secured to the axle via a key and hex screw.  Eventually, the gear on the axle will attach to the motor and be able to move independently for better turning and more finite control.
Rich text editor
