Testing the HRM-2511E sensor
A project log for Heart rate monitoring system
An open-source heart rate monitoring system based on the photoplethysmography principle.
rajendra-bhattRajendra Bhatt • 08/20/2014 at 02:43•0 Comments
I quickly setup a simple biasing circuit on a breadboard to check the raw pulse signal from the HRM-2511E sensor. Here's my circuit setup for this test.
I observed the waveform of the raw pulse signal output (Vout) from fingertip on my PC using my Analog Discovery tool from Digilent. The pulse signal waveform has amplitude of a few millivolts as shown below. This waveform was generated by wearing the sensor on my index finger.
